ผู้เขียน หัวข้อ: โปรแกรมสแกนรถ  (อ่าน 54803 ครั้ง)
ออนไลน์ Auto Car
  • กระทู้: 5846
Re: โปรแกรมสแกนรถ
« ตอบกลับ #45 เมื่อ: 17 กันยายน 2022, 11:10:57 »
On the machine you want to install G-IDSS on must NOT have any trace of previous install on ...
Disable Antivirus
Extract the archive "License Generator"
Go to C:\ProgramData make folder named "G-IDSS" inside folder save the licience file(ActivationData.dat) explained in "License Generator"
Once you have successfully done license for pc go to next step .
run G-IDSS 1.iso , run setup as administratior
continue with setup as you need to
if asked internet say yes online
when complete
update will come up and give error - this is ok
next , go extract loader and copy over files to directory where you installed it : C:\Program Files (x86)\G-IDSS\bin and overwrite , antivirus will give error for IDSS_STARTUP.exe so
be sure to add it to the exclusion list .
extract g-idss icon and also over write it in C:\Program Files (x86)\G-IDSS\bin
right click on shortcut on desktop G-IDSS and go to properties  : be sure to add \engver to the location must read something like : C:\Program Files (x86)\G-IDSS\bin\G-IDSS.exe /engver
next step is to do programming date fix , extract it and follow instructions given inside archive .
you can now run isuzu gidds
Note :
When you restart pc , webupdate client error will show : "cannot load required xml file xxxxxxxxxx" DO NOT CLOSE THIS TAB
To remove this error : go to start menue / run : msconfig
select Start up tab , look for Web Update Client , right click and say Disable .
Now you can close the error code tab
______________________________________________
OPTIONAL :  To add missing images to your install , please Find additional download link posted not included in these files
Download it , and extract to your install folder : example : C/PROGRAMS/G-IDSS/DATA/IMAGES      and overwrite .
once you have extracted missing images run the following inside : C:\Program Files (x86)\G-IDSS\bin
"ESIVehicleIDIndexer.exe" and "StringUpdate.exe" and "RegisterLibraries"
NOW FOR J2534 PASSTHRU DRIVERS :
Inside archive J2534 Passthru Drivers , you will find Drivers for Nexiq USB1/USB2 . GM MDI and Actia and Mongoose.
(if you require other for Volvo Interface VCADS then google the J2534 Drivers for it)
For Bosch KTS : You are not allowed to view links. Register or Login
Install your device needed , restart pc , then run gidds - select region , then top right corner at connection - select your interface .
ออนไลน์ Auto Car
  • กระทู้: 5846
Re: โปรแกรมสแกนรถ
« ตอบกลับ #46 เมื่อ: 17 กันยายน 2022, 11:11:41 »
บนเครื่องที่คุณต้องการติดตั้ง G-IDSS ต้องไม่มีร่องรอยของการติดตั้งก่อนหน้านี้บน ...
ปิดการใช้งานโปรแกรมป้องกันไวรัส
แยกไฟล์เก็บถาวร "License Generator"
ไปที่ C:\ProgramData สร้างโฟลเดอร์ชื่อ "G-IDSS" ภายในโฟลเดอร์ให้บันทึกไฟล์ใบอนุญาต (ActivationData.dat) ที่อธิบายไว้ใน "License Generator"
เมื่อคุณทำใบอนุญาตสำหรับพีซีสำเร็จแล้ว ให้ไปที่ขั้นตอนต่อไป
เรียกใช้ G-IDSS 1.iso เรียกใช้การตั้งค่าในฐานะผู้ดูแลระบบ
ตั้งค่าต่อตามที่คุณต้องการ
ถ้าถามเน็ตก็ตอบตกลงออนไลน์
เมื่อเสร็จแล้ว
การอัปเดตจะเกิดขึ้นและเกิดข้อผิดพลาด - ไม่เป็นไร
ต่อไป ไปแตกไฟล์และคัดลอกไฟล์ไปยังไดเร็กทอรีที่คุณติดตั้งไว้ : C:\Program Files (x86)\G-IDSS\bin และ overwrite โปรแกรมป้องกันไวรัสจะให้ข้อผิดพลาดสำหรับ IDSS_STARTUP.exe ดังนั้น
อย่าลืมเพิ่มลงในรายการยกเว้น
แยกไอคอน g-idss และเขียนทับใน C:\Program Files (x86)\G-IDSS\bin
คลิกขวาที่ทางลัดบนเดสก์ท็อป G-IDSS และไปที่คุณสมบัติ : อย่าลืมเพิ่ม \engver ลงในตำแหน่งที่ต้องอ่านเช่น C:\Program Files (x86)\G-IDSS\bin\G-IDSS.exe /engver
ขั้นตอนต่อไปคือการแก้ไขวันที่โปรแกรม แตกไฟล์และปฏิบัติตามคำแนะนำที่ให้ไว้ในไฟล์เก็บถาวร
ตอนนี้คุณสามารถเรียกใช้ isuzu gidds
บันทึก :
เมื่อคุณรีสตาร์ทพีซี ข้อผิดพลาดไคลเอนต์ webupdate จะแสดง: "ไม่สามารถโหลดไฟล์ xml ที่จำเป็น xxxxxxxxxx" อย่าปิดแท็บนี้
หากต้องการลบข้อผิดพลาดนี้ ให้ไปที่ start menue / run : msconfig
เลือกแท็บ Start up ค้นหา Web Update Client คลิกขวาแล้วพูดว่า Disable
ตอนนี้คุณสามารถปิดแท็บรหัสข้อผิดพลาด
_____________________________________________________________
ไม่บังคับ : หากต้องการเพิ่มภาพที่หายไปในการติดตั้ง โปรดค้นหาลิงก์ดาวน์โหลดเพิ่มเติมที่โพสต์ซึ่งไม่รวมอยู่ในไฟล์เหล่านี้
ดาวน์โหลดและแตกไฟล์ไปยังโฟลเดอร์การติดตั้งของคุณ: ตัวอย่าง: C/PROGRAMS/G-IDSS/DATA/IMAGES และเขียนทับ
เมื่อคุณแตกภาพที่หายไปแล้วให้เรียกใช้สิ่งต่อไปนี้: C:\Program Files (x86)\G-IDSS\bin
"ESIVEhicleIDIndexer.exe" และ "StringUpdate.exe" และ "RegisterLibraries"
ตอนนี้สำหรับไดรเวอร์ J2534 PASSTHRU:
ภายในไฟล์เก็บถาวร J2534 Passthru Drivers คุณจะพบไดรเวอร์สำหรับ Nexiq USB1/USB2 GM MDI และ Actia และพังพอน
(ถ้าคุณต้องการอย่างอื่นสำหรับ Volvo Interface VCADS ให้ google ไดรเวอร์ J2534 สำหรับมัน)
สำหรับ Bosch KTS : You are not allowed to view links. Register or Login
ติดตั้งอุปกรณ์ของคุณที่จำเป็น รีสตาร์ทพีซี จากนั้นเรียกใช้ gidds-select region จากนั้นมุมบนขวาที่การเชื่อมต่อ เลือกอินเทอร์เฟซของคุณ
ออนไลน์ Auto Car
  • กระทู้: 5846
Re: โปรแกรมสแกนรถ
« ตอบกลับ #47 เมื่อ: 19 กันยายน 2022, 18:49:21 »
ออนไลน์ Auto Car
  • กระทู้: 5846
Re: โปรแกรมสแกนรถ
« ตอบกลับ #48 เมื่อ: 19 กันยายน 2022, 18:55:58 »
ออนไลน์ Auto Car
  • กระทู้: 5846
Re: โปรแกรมสแกนรถ
« ตอบกลับ #49 เมื่อ: 19 กันยายน 2022, 19:07:48 »
- G-IDSS ใช้ได้ตั้งแต่ปี 2012- เป็นต้นไป
- GDS2 & TECH2WIN 11.2019 VMWARE
- G-IDSS 2020_VMWARE_nhanas
« แก้ไขครั้งสุดท้าย: 22 กันยายน 2022, 07:18:23 โดย Auto Car »
ออนไลน์ Auto Car
  • กระทู้: 5846
Re: โปรแกรมสแกนรถ
« ตอบกลับ #50 เมื่อ: 30 กันยายน 2022, 19:36:56 »
ลงกุญแจ
ออนไลน์ Auto Car
  • กระทู้: 5846
Re: โปรแกรมสแกนรถ
« ตอบกลับ #51 เมื่อ: 11 ตุลาคม 2022, 07:38:06 »
  โมหัวแทคติกให้เชื่อมต่อเน็ตเวิร์คได้
