ผู้เขียน หัวข้อ: พาร์ทกล่อง ECU TOYOTA  (อ่าน 5067 ครั้ง)
  • กระทู้: 5863
« เมื่อ: 15 พฤษภาคม 2020, 07:56:46 »
SCP10   1SZ   99y   A/T   FE   E/U 89661-52010
NCP60   2NZ   04y   A/T   FE   E/U 89661-52790  (4ป,4ช )
NCP20   2NZ       A/T   FE   E/U 89661-52360     ( 26,16,12,22 )
EP82   4E       M/T   FTE   E/U 89661-10100    26,16
EP82   4E   92y   A/T   FE   E/U 89661-10120
EP91   4E   97y   A/T   FE   E/U 89661-10170
EE102V   4E   97y   M/T   FE   E/U 89661-1A820   ( 26,16 - คอยล์ 2 ตัว )
EE101   4E   92y   A/T   FE   E/U 89661-1A200
EL51   4E   98y   A/T   FE   E/U 89661-16590   ( 26,16 - คอยล์ 2 ตัว )
NCP21   1NZ   03y   A/T   FE   E/U 89666-52030  (4ป,4ช )
NCP21   1NZ   99y   A/T,+/-   FE   E/U 89661-52400  (4ป,3ช )
NCP58G   1NZ   03y   A/T   FE   E/U 89666-0D130  (4ป,4ช )
NCP51V   1NZ   03y   A/T   FE   E/U 89661-52450  (4ป,3ช)
NZE121G   1NZ   03y   A/T   FE   E/U 89666-12390  (4ป,4ช )
NCP31   1NZ   00y   A/T   FE   E/U 89661-52810  (26,16,12,22)
NCP12   1NZ   99y   A/T   FE   E/U 89661-52610     ( 26,16,12,22 )
EXZ10   5E   99y   A/T   FE   E/U 89661-46010  ( 26,16 - คอยล์ 2 ตัว )
EL43   5E   94y   A/T   FE   E/U 89661-16210  ( 26,16 )
EE103   5E   01y   A/T   FE   E/U 89666-12330
EE103   5E   97y   A/T   FE   E/U 89661-1E170        (คอยล์ 2 ตัว )
EE104G   5E   96y   A/T   FE   E/U 89661-1A270    ( 26,16 )
ET196V   5E   96y   A/T   FE   E/U 89661-21140
ET196V   5E       A/T   FE   E/U 89661-2B610
AE110   5A   99y   A/T   FE   E/U 89661-1E020  ( 26,16 )
AE110   5A       A/T   FE   E/U 89661-1A440
AE100   5A   95y   A/T   FE   E/U 89661-1A130
AT212   5A   98y   A/T   FE   E/U 89661-2D810
AT190   5A   94y   A/T   FE   E/U,T/U 89661-2B540  ( 26,16,22 )
AE111G   4A   97y   A/T   FE   E/U,T/U 89661-1A371  ( 26,16,12 )
AE111N   4A   97y   A/T   FE   E/U,T/U 89661-13020  ( 26,16,12 )
AE101   4A   91y   A/T   FE   E/U,T/U 89661-
AE111   4A   97y   A/T   GE  (ดำ)   E/U 89661-1A480
AE101   4A   95y   A/T   GE  (ดำ)   E/U 89661-1A480
AE101   4A   92y   M/T   GZE   E/U 89661-12790
AE111   4A       M/T   GE  (ดำ)   E/U 89661-1A470
AT190   4A   92y   A/T   FE   E/U 89661-2B360
AT190   4A       A/T   FE   E/U 89661-2D230
AE115G   7A   95y   4W A/T   FE   E/U,T/U 89661-1A330 ( 26,16,12 ) คอยล์ในจานจ่าย
AT211   7A       A/T   FE   E/U 89661-2D800
AT211   7A   96y   A/T   FE   E/U 89661-2D580   ( 26,16,22 ) 2 คอยล์
AT211   7A   98y   A/T   FE   E/U 89661-21230
KR42V   7K   01y   M/T   E   E/U 89660-27050 (26,16)
ZZW30   1ZZ   99y   A/T   FE   E/U 89661-17590
ZZV50   1ZZ   01y   A/T   FE   E/U 89666-32010
ZZT240   1ZZ   02y   A/T   FE   E/U 89661-2G330 (4ป,4ช)
ZZT241   1ZZ   02y   A/T   FE   E/U 89661-21400
ZCA26   1ZZ   00y   A/T   FE   E/U 89661-42160
SX90   4S   93y   A/T   FE   E/U 89661-22490   ( 26,16,12 )
AZT250   1AZ   04y   A/T   FSE-D4   E/U 89661-2G360  ( 5ป,4ช )
SW20   3S       M/T   GE   E/U 89661-17480
SW20   3S       M/T   T/B   E/U 89661-17380
ST210   3S     99y   A/T   FSE-D4   E/U 89661-2G190     ( ทรอตเทิ้ลไฟฟ้า )
ST210   3S   96y   A/T   FE   E/U 89661-2D590    ( 26,16,22    2 คอยล์ )
ST191G   3S   93y   A/T    FE   E/U 89661-2B521   ( 26,16,12,22 )
ST202   3S   99y   M/T   GE-VVTI   E/U 89661-2G080
ST202   3S   95y   M/T   GE   E/U 89661-2D490
ST202   3S   94y   M/T   GE   E/U 89661-2B831   ( 26,16,12,22 )
ST205   3S   94y   4W M/T   T/B   E/U 89661-2B840,2B841  ( 26,16,22 )
ST185   3S       4W M/T   T/B   E/U 89661-20751
SV32   3S   90y   A/T   FE   E/U 89661-32650
ST191G   3S   97y   A/T   FE   E/U 89661-2D590
ST195G   3S   96y   4W A/T   GE   E/U 89661-21130
ST195G   3S   95y   4W A/T   GE   E/U 89661-21080  ( 26,16,12,22 )
ST202   3S   95y   A/T   FE   E/U 89661-2D380
ST215   3S           GE-VVTI   E/U 89661-21310
ST215   3S       4W A/T   T/B   E/U 89661-21330
SXM10   3S   97y   A/T   FE   E/U 89661-44010  ( 26,16,22 )
    3S       4W A/T   GE   E/U 89661-42290
SR40G   3S       A/T   FE   E/U 89661-28800
SXE10W   3S   01y   A/T   GE-VVTI   E/U 89661-53160 (5ป,3ช)
YXS11   3Y       A/T   PE   E/U 89661-43010
YR21G   3Y   93y   A/T   E   E/U 89661-28230  ( 26,16 )
YR21G   3Y       A/T   E   E/U 89661-28070  (10,18,14)
GXE10   1G   02y   A/T   FE-VVT   E/U 89661-53170 ( 4ป,3ช )
GX100   1G   00y   A/T   FE-VVT   E/U 89661-22850
SXV20W   5S       A/T   FE   E/U 89661-3T250
SXV15   5S   94y   A/T   FE   E/U 89661-33330,33500  ( 26,16,22 )
TCR10   2TZ   95y   A/T   FE   E/U 89661-28560 ( 26,16,22 )
TCR10W   2TZ   94y   A/T   FE   E/U 89661-28331 ( 26,16,22 )
MCV21   2MZ   96y   A/T   FE   E/U 89661-3T010  (4ป,4ช)
VCV11   4VZ   94y   A/T   FE   E/U 89661-33320
JZA70   1JZ   91y   A/T   GTE   E/U 89661-14470
JZX81   1JZ   90y   A/T   GE   E/U 89661-22380
JZX81   1JZ   90y   A/T   GTE   E/U 89661-22400
JZX90   1JZ   94y   A/T   GE   E/U DENSO No. 9717570-447-6
JZX90   1JZ       A/T   GTE   E/U 89661-22610
JZX100   1JZ   98y   A/T   GE-VVTI   E/U 89661-22740,22760  ( 4ป,4ช  )
JZX100   1JZ   99y   5 A/T   GE-VVTI   E/U 89661-2A040  (5ป,3ช )
JZX100   1JZ       A/T   T/B,VVTI   E/U 89661-22800 (4ป,4ช )
JZX100   1JZ   99y   A/T   T/B,VVTI   E/U 89661-2A050
JZX110   1JZ   01y   A/T,+/-   T/B,VVTI   E/U 89661-2A060
JZZ30   1JZ       A/T   GTE   E/U 89661-24280
JZS171W   1JZ   02y   5 A/T   GE-VVTI   E/U 89661-3A670
JZS171   1JZ   01y   5 A/T   FSE-D4   E/U 89661-3F250 (5ป,4ช )
JZS141   1JZ   93y   A/T   GE   E/U 89661-30620
JZS130G   1JZ   96y   A/T   GE-VVTI   E/U 89661-3A230   (4ป,4ช)
JZS151   1JZ   96y   A/T   GE   E/U 89661-3A060   ( 26,16,12,22 )
JZS151   1JZ   97y   A/T   GE   E/U 89661-3A250,251   (4ป,4ช)
JCG10   1JZ   99y   A/T   GE-VVTI   E/U 89661-51022   (5ป,3ช)
MCX10   1MZ   95y   A/T   FE   E/U 89661-07040   (4ป,4ช)
MCV20   1MZ   96y   A/T   FE   E/U 89661-33890   (4ป,4ช)
MCU10W   1MZ   00y   A/T   FE-VVT   E/U 89661-48032  (5ป,3ช)
VCV10   3VZ   92y   A/T   FE   E/U 89661-33200
VCV15W   3VZ       A/T   FE   E/U 89661-33200
JZX91   2JZ   93y   A/T   GE   E/U 89661-22420
JZX101   2JZ       A/T   GE-VVTI   E/U 89661-22771
JZA80   2JZ       M/T   GE   E/U 89661-14610
JZA80   2JZ       A/T    GTE   E/U 89661-14500
JZZ31   2JZ   94y   A/T   GE   E/U 89661-24340   (4ป,4ช)
JZS133   2JZ   92y   A/T   GE   E/U 89661-30540
JZS143   2JZ   94y   5 A/T   GE   E/U 89661-30770    ( A/T No. 30-50LE )
JZS135   2JZ   95y   A/T   GE   E/U 89661-30780
JZS155   2JZ   96y   A/T   GE-VVTI   E/U 89661-3A130
JZS155   2JZ   97y   A/T   GE-VVTI   E/U 89661-3A330     (  ทรอตเทิ้ลไฟฟ้า )  5 ปลั๊ก,3 ชั้น
JZS147   2JZ       A/T   GE   E/U 89661-30750,3A880,3A180
JZS147   2JZ       A/T   GTE   E/U 89661-30870
JZS161   2JZ   97y   A/T   T/B,VVTI   E/U 89661-3A470
JZS149   2JZ   93y   A/T   GE   E/U 89661-30510
JZS155   2JZ   97y   A/T   GE-VVTI   E/U 89661-3A350
JZS155   2JZ   96y   A/T   GE-VVTI   E/U 89661-3A110
VCH16W   5VZ   01y   4W A/T   FE   E/U 89661-26700 (5ป,3ช)
UZZ30   1UZ   91y   A/T   FE   E/U 89661-24220,24390
UZS141   1UZ   91y   A/T   FE   E/U DENSO No. 9717500-491-2
UZS141   1UZ   91y   A/T   FE   E/U 89661-30500
UZS151   1UZ   96y   A/T   FE   E/U 89661-3A080
UZS151   1UZ   99y   A/T   VVTi   E/U 89661-3A300
UCF11   1UZ   89y   A/T   FE   E/U 89661-50102   ( 26,16,22,26 )
UCF11   1UZ   92y   A/T   FE   E/U 89661-50170
UCF20   1UZ   96y   A/T   FE   E/U 89661-50241
UCF21   1UZ   97y   A/T   FE   E/U 89661-50380
UCF21   1UZ   99y   A/T   VVTi   E/U 89661-50521  [imo]
NL50   1N   95y   A/T   D/S,T/B   E/U 89661-16030 ( 26,16 )
CT210   2C   96y   A/T   D/S,T/B   E/U 89551-20130  ( 26,16 )
CE107V   3C   01y   A/T   D/S,E   E/U 89661-1E230  ( 26,16,12,22 )
CXR10   3C   91y   2W A/T   D/S,T/B   E/U 89551-28070  ( 26,16,12 )
CXR10   3C   94y   2W A/T   D/S,T/E   E/U 89661-28310  ( 26,16,22 )
CXR20G   3C   94y   4W A/T   D/S,T/E   E/U 89661-28580  ( 26,16,22 )
LH100   2L       A/T   D/S,T/B   E/U,T/U  89551-26070   (26,16,12)
KCH11   1KZ-Inter   01y   4W A/T   D/S,T/B   E/U 89661-26690
KZH120G   1KZ-Inter    00y   A/T   D/S,T/B   E/U 89661-26630      ( 4 ปลั๊กขาว,3 ชั้น / คันเร่งไฟฟ้า )
KZH100   1KZ   00y   A/T   D/S,T/B   E/U 89661-26630      ( 4 ปลั๊กขาว,3 ชั้น / คันเร่งไฟฟ้า )
KZH106   1KZ   95y   4W A/T   D/S,T/B   E/U 89661-26180
KZH100G   1KZ   95y   A/T   D/S,T/B   E/U 89661-26170 ( 26,16,12 )
LN147   5L   99y   M/T   D/S   E/U 89661-35080 ( 26,16 )
    1JZ-GE       A/T   GE-VVTi   E/U 89661-22740    (4ปลั๊กขาว,4ชั้น )
    7A-FE       A/T   GE   E/U89661-2D210
    2JZ-GTE       A/T   GTE   E/U 89661-30560  ( ปลั๊กขัน +เสียบ )
JZZ3   2JZ    97y   A/T   GE-VVTi   E/U 89661-24540    ( 5 ปลั๊กขาว,3 ชั้น / คันเร่งไฟฟ้า )
JZS171   2JZ   99y   A/T   GE-VVTi   E/U 89661-3F470     (5 ปลั๊กขาว,3ชั้น  /ค้นเร่งไฟฟ้า )
