ผู้เขียน หัวข้อ: Him  (อ่าน 11180 ครั้ง)
  • กระทู้: 5863
Re: Him
« ตอบกลับ #15 เมื่อ: 02 กุมภาพันธ์ 2021, 07:04:41 »
Toyota Techstream v15.00.026 Multilingual + Loader
Win | 226 MB
• O.S.: Windows 7, Windows 8, Windows 8.1, Windows 10
• CPU: Intel/AMD 1.5 GHz or higher
• RAM: 2 GB of system memory
• Hard Drive: 5 GB of available space
• Compatible devices: Toyota MINI VCI cable, Xhorse MVCI cable
• Optical Drive: DVD-ROM
- TOYOTA Techstream V15.20.021 (08/2020) + Activation
« แก้ไขครั้งสุดท้าย: 02 กุมภาพันธ์ 2021, 13:25:48 โดย Auto Car »
  • กระทู้: 5863
Re: Him
« ตอบกลับ #16 เมื่อ: 02 กุมภาพันธ์ 2021, 13:21:17 »
- Ford and Mazda IDS 120 Full + VX Drivers and Patch
Full V120 Software Drivers and Patch for VCM and VX Nano which can run both Ford and Mazda Software on separate PC's Windows XP 7 8 & 10 32 or 54 bit
Please leave thanks and Rep before requesting your password here!
Installation must be done on a fresh windows OS unlike VM ware versions of IDS any other auto diagnostic software is likely to cause conflicting issues
If IDS has previously been installed on your PC it is best reinstall new Windows OS as the patch is unlikely to work with conflicting issues in the registry values
Disable AntiVirus before downloading or using Patch Set your AV to restore/Ignore Patch to allow use of it!
Install and reboot IDS software Delete and never use the IDS desktop Shortcut!
Next load the VCI software 1.00.10 When completed Open desktop Shortcut Click on VCMII for the first time then remove it from desktop
Next load VCI Manager 20.11.24 after completion open the new desktop shortcut
Connect your VCM USB to your Laptop with the Desktop Shortcut still open Click on connect VCM2
Copy the patch to your desktop it is not installed it just sits on the desktop
Open patch only after connection has been confirmed with the green tick
After it has loaded up enter Non Dealer 00000 UK for the first instance of use
To use IDS you must Connect VCM USB to Laptop Open The Desktop Shortcut Click connect VCM2 Open patch only after connection is confirmed with the tick
Any problems installing or using this please post on this forum for all to share the knowledge DO NOT BE SELFISH AND POST ME PRIVATE MESSAGES JUST TO HELP ONLY YOU
After THANKS and REP is seen I will automatically send the PASS within 24 hours You do not need to request it! I am tired of asking Do Not request in my private messages!
If you pester me and block up my private messages you will need to wait 48hrs for the PASS!
   กด Thanks แล้ว แต่ยังไม่ได้กด Rep
2 กพ 64  13:23 น.
  กด Rep และส่งอีเมล์ไปแล้ว
3 กพ 64 06:37
« แก้ไขครั้งสุดท้าย: 03 กุมภาพันธ์ 2021, 06:34:10 โดย Auto Car »
