ผู้เขียน หัวข้อ: สอนใช้งานMUT3  (อ่าน 9984 ครั้ง)
  • กระทู้: 5863
Re: สอนใช้งานMUT3
« ตอบกลับ #15 เมื่อ: 15 ตุลาคม 2024, 14:20:14 »
MMCodingWriter 2.1
  • กระทู้: 5863
Re: สอนใช้งานMUT3
« ตอบกลับ #16 เมื่อ: 15 ตุลาคม 2024, 14:21:40 »
MMCodingWriter + MUT Coding free software for ETACS programing
MMCodingWriter is a free software for change hidden options (coding) and diagnostics Mitsubishi vehicles
No internet required. No limits for any operation.
Free equivalent of MUT-III (partially) and Etacs Decoder.
Support all vehicles, where present ETACS starting 8637A313 and furhter. (including some Peugeot/Citroen models)
Support all J2534-compatible adapters (tested on Toyota Mini-VCI, OpenPort 2.0) and true ELM327 (USB/Bluetooth) 1.5
Please, use google translate or similar. Translations will be added later.
1. Change variant coding
2. Change custom coding
3. Change coding in Engine ECU .
4. SAS calibration / G-sensor calibration.
5. Read/erase DTCs.
6. Turn on/off seatbelt reminder on dash (not working on 8100B900 and later).
7. Read/adapt RLS.
8. Erase engine adapts.
9. Change VIN in ETACS and engine.
10. Read errors history with ODO at DTC.
11. Change service reminder
12. Read A/C system pressure
13. Change Immo PIN (soon)
To edit saved coding files use MUT Coding Mitsubishi tool.
Vehicles:
Lancer X, Outlander 3, Outlander XL, L200 2016+, Pajero sport 2016+, ASX, Delica D5, Citroen C-Crosser, Peugeot 4007.
Adapters:
Toyota Mini-VCI
Scanmatik 2
OpenPort 2.0
Chipsoft J2534 lite
VAG K + CAN Commander with vdiag.net driver
UCDS
(Any J2534 compatible adapters are supported)
ELM327 Bluetooth 1.5
ELM327 USB 1.5
ELS27
Actual version 2.1
You must be logged in to download
MMCodingWriter2.1.zipRequired .NET framework 4.0 and Visual C++ redist 2014 x86
MMCodingWriter - You are not allowed to view links. Register or Login
MUT Coding - You are not allowed to view links. Register or Login
MUT-III J2534 Driver - You are not allowed to view links. Register or Login
  • กระทู้: 5863
Re: สอนใช้งานMUT3
« ตอบกลับ #17 เมื่อ: 15 ตุลาคม 2024, 14:27:53 »
ลง mut3 ถ้าผ่านขั้นตอน database ได้ ก็ฉลุย
ถ้าลงขั้นนี้ไม่ผ่าน ใครมีวิธีแก้บ้างหน้อ
ผมไล่ลงวินโดว์ใหม่อย่างเดียว
ดาต้าไม่ผ่านก็ไม่เป็นไรครับ ขอแค่ icon mut ขึ้นบนหน้าจอ ก็ถือว่าผ่านครับ แล้วค่อยไปลง mut seทีหลังครับ
มันจะลงข้อมูลการซ่อมไม่ได้ด้วยครับ แต่ถ้าต้องการแค่mut-seก็ปล่อยผ่านได้
ขั้นตอนการลง Databases อะผ่านครับ เพียงแค่ SQL ต่างหาก ที่ไม่ผ่าน SQL ขึ้นอยู่กันWindows ว่าตอน อพเดท มันสมบูรณ์มั้ย ถ้าเป็นไปได้ แนะนำให้ อัพเดท Windows ให้เรียบร้อยก่อน แล้วค่อยมาลง Mut
ใช่ๆ มันฟ้อง SQL พอดีไม่ได้เจอนานแล้วครับ
  • กระทู้: 5863
Re: สอนใช้งานMUT3
« ตอบกลับ #18 เมื่อ: 15 ตุลาคม 2024, 14:31:16 »
ต้องเปิด​ Enable​ Driver​ signature ก่อนครับ​ใน​ google​ มีสอนอยู่ครับ​เพราะการเปิดโหมดนี้​ในคอมแต่ละเครื่อง​
จะมีวิธีการไม่เหมือนกันครับ
เปิดระบบคอมพิวเตอร์​เป็น​ Test​ Mode​ รึยังครับ
